incognito91564
#1 Posted : Saturday, January 29, 2011 12:29:36 PM(UTC)
incognito91564
press start and hold hear timer hum as if it has a motor running and click electric motor does not start where should i start trouble shooting checked pig tail ,its good ,the plug wire thanks all dryer door parts are ok switch not tested yet.
#2 Posted : Sunday, January 30, 2011 1:59:55 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for FRIGIDAIRE FDE648GFS0 Frg(v1) / Dryer | AppliancePartsPros.com
[COLOR="DarkRed"]checked pig tail ,its good [/COLOR]
Sorry but I do nor understand what you mean.
If the interior light works then you know power (L1 to Neutral) for the motor is OK..
I would check the thermal limiter (fuse) (Item 36 in Section1) first.
Unplug the unit.
Remove one wire from the fuse and check it with a meter.
Should be 0 ohms.
If it is blown then replace it and check/clean your vent suystem as this is the most common cause of it going.
Not a bad idea to also clean/check your blower wheel.
Next would be the door switch and then the start switch.
incognito91564
#3 Posted : Sunday, January 30, 2011 9:25:23 AM(UTC)
incognito91564
Unplug the unit.
Should be 0 ohms.
thanks it was the thermal limiter aka fuse got 0 ohms reading jumper out fuse dryer runs normal blower blows good good heat gonna run this way entil new parts come in
#4 Posted : Sunday, January 30, 2011 11:00:48 PM(UTC)
Replace the fuse ASAP as this is a critical safety device.
If you have a heater fault running without the fuse could cause a lint fire which can turn into a house fire.
