scoldoc@gmail.com
#1 Posted : Saturday, January 29, 2011 8:43:46 AM(UTC)
scoldoc@gmail.com
Dryer not drying well. I cleaned all lint out of machine and replaced exhaust duct.The element gets red hot but doesnt stay on the whole time. I think that I should probably replace the thermostats . there seems to be 4 different theromstat or cut off type devices.
#2 Posted : Sunday, January 30, 2011 2:59:22 AM(UTC)
Replacement parts for KENMORE 11063952101 | AppliancePartsPros.com
Here is the tech sheet, see attachment.
[COLOR="DarkRed"]The element gets red hot but doesn't stay on the whole time.[/COLOR]
Not sure what you mean. It is normal for te element to turn on/off during the cycle. It is either full on or full off.
Read more: http://forum.appliancepartspros...rying.html#ixzz1CWE7i7Yy
http://forum.appliancepartspros.com
Try diagnostics to see if anything comes up.
The unit uses a thermistor to sense the temperature so I would check it with a meter.
Could be you are running off the high limit and may also have a grounded element.
I would do the following first just to be 100% sure you do not still have a venting problem.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
File Attachment(s):
63952101.pdf (295kb) downloaded 10 time(s).
scoldoc@gmail.com
#3 Posted : Sunday, January 30, 2011 5:07:32 AM(UTC)
scoldoc@gmail.com
thanks ,good advise. i went to sears and bought a new theromstat and high limit switch , it fixed the problem.
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
LG DLEX5780WE not drying all the way (Dryer Repair)
by LMA 3/2/2023 8:24:25 AM(UTC)
Whirlpool WDF750SAYM3 not drying (Dishwasher Repair)
by pashwin 2/19/2023 9:20:03 AM(UTC)
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Amana Dishwasher Not Drying The Dishes (Dishwasher Repair)
by mark@homeplanco.com 9/21/2020 7:32:33 AM(UTC)
LG dryer not drying clothes (Dryer Repair)
by DGRA0005 7/6/2020 5:42:51 PM(UTC)
Whirlpool wed4800bq1 dryer not drying very good (Dryer Repair)
by t3i 3/19/2019 3:10:19 PM(UTC)
Whirlpool WDF320PADS2 not drying. (Dishwasher Repair)
by fordsbyjay 2/5/2019 10:36:25 AM(UTC)
Dryer not drying (Dryer Repair)
by Scotty dog 12/3/2017 10:46:30 AM(UTC)
Dryer not Drying Clothes (Dryer Repair)
by Epfever1 12/1/2017 9:44:44 AM(UTC)
dryer not drying and water in drum (Dryer Repair)
by sonjawainwright 8/23/2017 8:07:12 AM(UTC)
Matag Dryer not drying in Intellidry Mode (Dryer Repair)
by themooser98 8/23/2017 5:43:28 AM(UTC)
Not drying after replacing element (Dryer Repair)
by Stacybrown 7/8/2017 11:10:47 AM(UTC)
