jlux824
#1 Posted : Saturday, January 29, 2011 3:13:32 AM(UTC)
jlux824
My dishwasher fills with water and the washing indicator light comes on but does't wash. It drains after a while by itself. Its the same for all of the wash options. Whats up?
#2 Posted : Saturday, January 29, 2011 3:57:28 AM(UTC)
Replacement parts for FRIGIDAIRE FDB1050REQ2 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154547901.pdf
You could try the diagnostics (water service test).
Measure across the wash motor when it should be running.
If you have 120 volts then the motor is probably toast.
If you have 0 volts then the most likely culprit is the control board.
Have you tried removing power from the unit for 5 minutes or so to see if it will reset.
