30" Electric Wall Oven W/ERC III control and motorized door lock. Reaches selected temperature then flashes "F2" code, beeps and shuts down. Thermal Limit Switch, Fan Thermal Limit Switch and Oven Temperature Sensor all replaced. Cooling fan operates and all connections are proper and tight. The Key Panel Test was done and all buttons beep and operate and display is correct. Is last item that could be defective the "Oven Control Module"? Please advise. Pricey item.
