John Laser
#1 Posted : Friday, January 28, 2011 11:01:30 PM(UTC)
John Laser
30" Electric Wall Oven W/ERC III control and motorized door lock.
Reaches selected temperature then flashes "F2" code, beeps and shuts down.
Thermal Limit Switch, Fan Thermal Limit Switch and Oven Temperature Sensor all replaced. Cooling fan operates and all connections are proper and tight. The Key Panel Test was done and all buttons beep and operate and display is correct.
Is last item that could be defective the "Oven Control Module"?
Please advise. Pricey item.
kayakcrzy
#2 Posted : Saturday, January 29, 2011 3:02:04 AM(UTC)
kayakcrzy
Appliance Fault Codes Range / Stove / Oven Fault Codes Click on that link, and it will tell you that the clock control board is the issue. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
F2 fault code (Dryer Repair)
by smartfan1997 7/23/2014 5:26:41 PM(UTC)
Whirlpool Range/Oven has F2 fault Code (Oven Repair (including Ranges and Cooktops))
by Josie430 11/23/2012 8:49:09 AM(UTC)
