mrshiff
#1 Posted : Saturday, December 6, 2008 4:58:13 AM(UTC)
mrshiff
can a chip in the finish of a washer drum be repaired
#2 Posted : Saturday, December 6, 2008 5:56:48 AM(UTC)
I have never done this but it should work.
Clean the area with a soap solution and then with vinegar.
Get it as clean as you can
If rusty sand it with medium emery cloth till clean.
If the area is a little rough the coating will adhere better.
Then I would get a bottle of the stuff that is used to repair dishwasher racks.
It has good adhesion and soap has no effect on it.
I would paint on several light coats instead of one heavy coat.
Could also use an epoxy buy get one that is optimized for metal.
5 minute epoxy will just peel off after a few washes.
Perhaps someone else will have personal experience with this a specific epoxy to use.
Washer drum out of balance on spin (Washer Repair)
by breckrider 2/4/2018 4:59:32 PM(UTC)
washer drum dosent turn smoothly (Washer Repair)
by brianrb 4/23/2017 4:53:14 AM(UTC)
Maytag centennial washer drum sits too low (Washer Repair)
by jansmeall 12/8/2016 11:59:20 AM(UTC)
Washer drum not spinning (Washer Repair)
by cw1 8/14/2015 5:22:57 PM(UTC)
LG washer drum won't turn (Washer Repair)
by Jmccaslin 10/10/2014 1:58:48 PM(UTC)
Washer drum has paint peeling off (Washer Repair)
by ChristiKate 10/1/2014 5:25:42 AM(UTC)
Kenmore Washer drum rotating speed? (Washer Repair)
by HankMcDermott 3/3/2014 9:40:25 AM(UTC)
washer drum will not turn (Washer Repair)
by emf 11/17/2013 2:54:42 PM(UTC)
Washer drum huge spill. (Washer Repair)
by That One Guy 6/13/2013 9:36:40 PM(UTC)
GE Adora washer drum unsecure? (Washer Repair)
by mattdenney07 10/28/2012 11:56:59 AM(UTC)
Washer Drum Appears to not be suspended in front (Washer Repair)
by tnadkins 5/22/2012 1:47:01 PM(UTC)
Washer Drum Hits Front of Cabinet (Washer Repair)
by mydogsmom 1/24/2012 2:00:13 PM(UTC)
Washer drum won't turn (Dishwasher Repair)
by gregndella 12/8/2011 8:00:39 PM(UTC)
Washer drum finish wearing away (Washer Repair)
by LA712 11/3/2011 6:22:43 PM(UTC)
Washer drum want turn (Washer Repair)
by jimmie_lou 10/31/2011 7:05:27 PM(UTC)
