2 Pages12>
ddavis263
#1 Posted : Thursday, January 27, 2011 11:21:26 AM(UTC)
ddavis263
If i'm only getting 120 to the heating element does that mean the timer is shot?
#2 Posted : Thursday, January 27, 2011 12:55:21 PM(UTC)
Did you check the circuit breakers?
What is the complete model number of the dryer?
SteveKJR
#3 Posted : Thursday, January 27, 2011 12:56:22 PM(UTC)
SteveKJR
If it is a 208/230 element you should be getting 208 volts across both terminals. Start backtracking from each side of the element - sometimes there is a "fusable link" that fails - its a small wire with a little ball in the center of it.
If you see one of those, disconnect it and check continuity through it - if you don't get any reading, it's probably bad.
SteveKJR
ddavis263
#4 Posted : Thursday, January 27, 2011 1:30:24 PM(UTC)
ddavis263
Its a Maytag LDE412
#5 Posted : Thursday, January 27, 2011 1:58:43 PM(UTC)
Its a Maytag LDE412
Pull the dryer out of the wall. Remove the terminal block cover. While the dryer is off and the power cord is plugged into the wall outlet, check the voltage between the Red and the White wires and between the Black and the White wires at the terminal block. It suppose to be 120 VAC on each pair. Then check the voltage between the Red and the Black wires. The normal reading suppose to be 240 VAC.
If any of the readings is incorrect, there is a problem with the house power.
Here are the breakdown diagrams and Replacement parts for MAYTAG LDE412 DRYER- ELE | AppliancePartsPros.com
ddavis263
#6 Posted : Thursday, January 27, 2011 3:39:15 PM(UTC)
ddavis263
House power is fine. Other dryers work fine on the same recepticial.
#7 Posted : Thursday, January 27, 2011 3:42:43 PM(UTC)
When it was last time you had an other dryer hooked up to the same outlet?
Can you describe in details how did you check the voltage to the heating element?
lindak00
#8 Posted : Thursday, January 27, 2011 3:56:56 PM(UTC)
lindak00
yes the circuit breakers are fine. and the model # MDE4806AYW
lindak00
#9 Posted : Thursday, January 27, 2011 3:59:00 PM(UTC)
lindak00
the breakers are fine. the model # mde4806ayw
lindak00
#10 Posted : Thursday, January 27, 2011 4:08:40 PM(UTC)
lindak00
some ome told me to replace the control board on the dryer I dont know what to do
2 Pages12>
