Icemaker has ice running down back wall. Ordered water filter for unit. next step?
Does it have a water dispenser too?
The model number you posted is incorrect. Verify and repost it please.
Yes, it does have an inside water dispenser that's never used. The model number I copied is ET1FTTXQ00. I can re-check with my reading glasses...if needed.
You probably missed "K" between "X" & "Q". Most likely the problem is a bad water inlet valve on the back of the refrigerator. - The water inlet valve Part number: AP3890667
Thanks! Easy to replace? Inside or ouside of fridge? Thanks again..my wife will be happy.
Pull the refrigerator out of the wall. Remove the cover on the bottom and you'll see it.
If you know how to handle a simple tools, this part should not be too difficult to replace yourself.
