retirednow
#1 Posted : Tuesday, January 25, 2011 9:42:36 AM(UTC)
retirednow
Icemaker has ice running down back wall. Ordered water filter for unit. next step?
#2 Posted : Tuesday, January 25, 2011 1:04:58 PM(UTC)
Does it have a water dispenser too?
The model number you posted is incorrect. Verify and repost it please.
retirednow
#3 Posted : Tuesday, January 25, 2011 1:43:10 PM(UTC)
retirednow
Yes, it does have an inside water dispenser that's never used.
The model number I copied is ET1FTTXQ00. I can re-check with my reading glasses...if needed.
#4 Posted : Tuesday, January 25, 2011 5:42:34 PM(UTC)
You probably missed "K" between "X" & "Q".
Most likely the problem is a bad water inlet valve on the back of the refrigerator.
- The water inlet valve Part number: AP3890667
retirednow
#5 Posted : Tuesday, January 25, 2011 5:54:26 PM(UTC)
retirednow
Thanks!
Easy to replace? Inside or ouside of fridge?
Thanks again..my wife will be happy.
#6 Posted : Tuesday, January 25, 2011 6:04:39 PM(UTC)
Pull the refrigerator out of the wall. Remove the cover on the bottom and you'll see it.
If you know how to handle a simple tools, this part should not be too difficult to replace yourself.
