when i pull the timer switch to fill the washer nothing happens. i replaced the lid switch fuse & still nothing any suggestions?
did you repalce the whole module?22001682 is the old maytag number
no i did not replace the whole module just the fuse.
May sound silly, but first, make sure you're getting power from the outlet. Do you hear a faint hum when you start the machine? Is the water turned on?
water is turned on. there is no faint hum that i can hear. seems like the switch does nothing when pulled.
Do you own, can you use, a multi-meter?
yes i can use a multi-meter. may need detailed instructions where to test though. i have limited experience with washing machines.
