niners805
#1 Posted : Thursday, December 4, 2008 10:33:52 AM(UTC)
niners805
when i pull the timer switch to fill the washer nothing happens. i replaced the lid switch fuse & still nothing any suggestions?
v2k04
#2 Posted : Thursday, December 4, 2008 11:41:01 AM(UTC)
v2k04
did you repalce the whole module?22001682 is the old maytag number
niners805
#3 Posted : Thursday, December 4, 2008 11:56:43 AM(UTC)
niners805
no i did not replace the whole module just the fuse.
magician59
#4 Posted : Thursday, December 4, 2008 1:48:14 PM(UTC)
magician59
May sound silly, but first, make sure you're getting power from the outlet. Do you hear a faint hum when you start the machine? Is the water turned on?
niners805
#5 Posted : Thursday, December 4, 2008 5:26:31 PM(UTC)
niners805
water is turned on. there is no faint hum that i can hear. seems like the switch does nothing when pulled.
magician59
#6 Posted : Friday, December 5, 2008 7:22:16 AM(UTC)
magician59
Do you own, can you use, a multi-meter?
niners805
#7 Posted : Friday, December 5, 2008 8:32:25 AM(UTC)
niners805
yes i can use a multi-meter. may need detailed instructions where to test though. i have limited experience with washing machines.
