Problem w/ water in tub after cycle complete. Changed mixing valve and worked for a short time. Then noticed problem again. Suspect faulty timer/control....but reluctant to change this costly item if not necessary.
Any help here would be greatly appreciated
Hocko
Check your pump for an obstruction.
Nat
The chances of a TIMER doing this VERY SLIM!!!!! How much water is left in the tub? Is the water there when the cycle ends? or does it take a while to show up in the tub? Please don't guess, the better info you give us, the better I (we) can help!!! Thanks!!!!!!!!!:D
