hocko
#1 Posted : Thursday, December 4, 2008 8:35:26 AM(UTC)
hocko
Problem w/ water in tub after cycle complete. Changed mixing valve and worked for a short time. Then noticed problem again. Suspect faulty timer/control....but reluctant to change this costly item if not necessary.
Any help here would be greatly appreciated
Hocko
libertyappl
#2 Posted : Thursday, December 4, 2008 2:36:36 PM(UTC)
libertyappl
Check your pump for an obstruction.
Nat
Drags1998
#3 Posted : Thursday, December 4, 2008 3:15:32 PM(UTC)
Drags1998
The chances of a TIMER doing this VERY SLIM!!!!! How much water is left in the tub? Is the water there when the cycle ends? or does it take a while to show up in the tub? Please don't guess, the better info you give us, the better I (we) can help!!! Thanks!!!!!!!!!:D
