While in the process of washing a load the dishwasher makes a deep smooth sound. it comes and goes. I also think that the water isn't moving around inside like it should . The dishes don't come out as clean as they should.
Check the water level inside. Make sure all holes in the spray arms are open. Remove the toe panel and check if the motor is running.
