evrard102
#1 Posted : Thursday, December 4, 2008 4:21:32 AM(UTC)
evrard102
While in the process of washing a load the dishwasher makes a deep
smooth sound. it comes and goes. I also think that the water isn't moving around inside like it should . The dishes don't come out as clean as they should.
#2 Posted : Friday, December 5, 2008 1:33:01 PM(UTC)
Check the water level inside. Make sure all holes in the spray arms are open. Remove the toe panel and check if the motor is running.
