rhode99
#1 Posted : Wednesday, December 3, 2008 11:57:25 AM(UTC)
rhode99
Kenmore Elite HE4
1 in 5 loads this machine will stop and flash f/h code. I checked all water lines going in and discharge, nothing blocked. Water pressure is up to 80 lbs. I even had a repair guy run a diag check and he found nothing.He checked fill valve inlet valves flowmeter etc and said it is all working. So does anyone have any ideas??
thanks Model#110.45986400
libertyappl
#2 Posted : Wednesday, December 3, 2008 12:17:02 PM(UTC)
libertyappl
This is straight out of the manual.
Potential Causes
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Nat
rhode99
#3 Posted : Wednesday, December 3, 2008 3:30:36 PM(UTC)
rhode99
that was all done today and nothing was found wrong
whirlpool duet ghw9100 washer f/h code (Washer Repair)
by rtbme 4/13/2011 8:30:44 PM(UTC)
