Kenmore Elite HE4 1 in 5 loads this machine will stop and flash f/h code. I checked all water lines going in and discharge, nothing blocked. Water pressure is up to 80 lbs. I even had a repair guy run a diag check and he found nothing.He checked fill valve inlet valves flowmeter etc and said it is all working. So does anyone have any ideas?? thanks Model#110.45986400
This is straight out of the manual. Potential Causes
• If there is no water in the unit: • Make sure that both valves at the water source(s) are turned on all the way. • Check for plugged or kinked inlet hoses or plugged screens in the inlet valves • Verify inlet valve operation • If there is water in the unit: • Verify Drain pump operation • Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch • Verify there is not a siphon problem • Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU) • Check all hoses for possible leaks • Verify pressure switch operation • Verify flow meter operation • Verify CCU operation
Nat
that was all done today and nothing was found wrong
