Unable to find in error code
THIS FORUM IS DEAD!!!!!!! |
There is no keypad on this model. It is just a peel off front cover. You need to replace the clock control board. The part # is 316557104. When you remove the old clock control board, which is held in by 4 screws, just pull off the front pad, with the bake, and broil, and clock time, and stick in on the new one. This is a quick and easy repair. Take me about 15 minutes to do it all. Make sure you unplug the oven, when you do it. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
