ExCuse77
#1 Posted : Tuesday, December 2, 2008 5:54:10 PM(UTC)
ExCuse77
The problem that I have on the upper oven is that it does not reach or hold the desired temp. The lower oven is fine. On the upper oven I changed the door gasket and the thermocouple and I swapped the lower heating element from the lower oven. I also cranked in a 35 F offset and still no improvement. Does this point to a bad control board AP3095479 (black). How can I test the board before I spend a load on a replacement. Thanks.
ExCuse77
#2 Posted : Tuesday, December 2, 2008 5:57:52 PM(UTC)
ExCuse77
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
kayakcrzy
#3 Posted : Wednesday, December 3, 2008 4:46:27 AM(UTC)
kayakcrzy
Yes, you are right on point. Tom ApplianceEducator.com
Oven will not hold temp (Oven Repair (including Ranges and Cooktops))
by jmelies 11/6/2012 7:17:35 AM(UTC)
Oven will not hold temp! Already tried Control Board & Sensor! Now what??? (Oven Repair (including Ranges and Cooktops))
by NicCar99 12/2/2008 8:05:52 PM(UTC)
Electric oven will not hold temperature evenly (Oven Repair (including Ranges and Cooktops))
by ed4ster 11/16/2008 5:13:15 PM(UTC)
