ExCuse77
#1 Posted : 16 years ago
ExCuse77
The problem that I have on the upper oven is that it does not reach or hold the desired temp. The lower oven is fine. On the upper oven I changed the door gasket and the thermocouple and I swapped the lower heating element from the lower oven. I also cranked in a 35 F offset and still no improvement. Does this point to a bad control board AP3095479 (black). How can I test the board before I spend a load on a replacement. Thanks.
ExCuse77
#2 Posted : 16 years ago
ExCuse77
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
kayakcrzy
#3 Posted : 16 years ago
kayakcrzy
Yes, you are right on point. Tom ApplianceEducator.com
Oven will not hold temp (Oven Repair (including Ranges and Cooktops))
by jmelies 12 years ago
Oven will not hold temp! Already tried Control Board & Sensor! Now what??? (Oven Repair (including Ranges and Cooktops))
by NicCar99 16 years ago
Electric oven will not hold temperature evenly (Oven Repair (including Ranges and Cooktops))
by ed4ster 16 years ago
