Andersonj
#1 Posted : Tuesday, December 2, 2008 4:36:01 PM(UTC)
Andersonj
the glow ignitor heats intermittently. Tested with multi meter and got 81.5 ohms.
Also tested solenoids - I got 1205 ohms on the 2- prong coil. the three prong coil gave me 549 for the left and right prongs; middle and right gave me 1900; middle prong and left prong gave me 1352ohms. these were unplugged.
I removed and tested the flame sensor on the burner housing and got 00.7 ohms.
anyone have ideas. so far nothing seems to have solved the problem.
#2 Posted : Wednesday, December 3, 2008 4:05:13 PM(UTC)
The igniter is operated by the thermostat and normally should cycle "on" and "off" depends on the temperature. Is that what you meant saying: "the glow igniter heats intermittently"?
If it stays "on" not long enough to maintain a proper temperature then there is a lack of air flow through the dryer due to clogged vents outside the dryer as well as inside.
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Ge dryer wont heat up (Dryer Repair)
by CLARK12 8/2/2009 12:36:31 PM(UTC)
GE dryer wont heat at all (Dryer Repair)
by denisegraham 5/21/2009 4:52:38 PM(UTC)
