IreneSN99
#1 Posted : Wednesday, January 19, 2011 10:41:37 AM(UTC)
IreneSN99
My older but very functional Jenn Air down draft range with oven has a fan noise problem. Still works but fan is getting very noisy. Must it be replaced? If so, please give me some hints and tips on how to proceed without paying more than the cost of a new stove. Thank you so much.
magician59
#2 Posted : Wednesday, January 19, 2011 11:04:48 AM(UTC)
magician59
You'll need to determine whether the noise is coming from the fan motor itself, or the blower wheel.
Part number: AP4009957
IreneSN99
#3 Posted : Wednesday, January 19, 2011 12:25:57 PM(UTC)
IreneSN99
Thanks so much for your reply. When I looked at the parts list, I saw the fan wheel and began to think its the wheel. How can I tell if its the fan motor or the blower wheel? Where is the blower wheel in the stove? Thanks again.
magician59
#4 Posted : Wednesday, January 19, 2011 12:53:50 PM(UTC)
magician59
It' part #10 in this drawing. It's located in the down-draft assembly.
Replacement parts for JENN-AIR S160 RANGE- S/C S/I DDRAFT ELE | AppliancePartsPros.com
IreneSN99
#5 Posted : Wednesday, January 19, 2011 4:27:21 PM(UTC)
IreneSN99
Thanks again. Please help this layperson locate it on the physical stove.
When I open the oven, on the back wall I can see a cover with holes (looks like it unscrews). I had assumed that the fan was behind the cover.
Where is the blower wheel relative to this cover?
Also, once I open things up, is there a way I can tell whether it is the blower wheel or the fan motor making the noise? Thanks.
