If the maintenance man tells that the heating element is faulty ; this is simple to check out, move out the rightside panel and you could assess the opposition of the heating element (providing you have a tester meter) To me it does n't create any sense to exchange the thermostat at the same time, in point of fact the heating element comes complete with thermostat (which constists of two mixed bits ; NTC factor and a maximum thermostat.
Possibly this man is n't rather sure about his own conclusions, at least he doesn.
Hi everyone! Welcome to our website. Check out. brilliant hoodia
Hello everyone! Check out. wonderful hoodia
Replace the manage module solved the proper and it's back to showing.
Our 2006 Bosch DW (SHU43C05UC) started the long run time symptom this week end. Found this forum, followed the thread and downloads to the classic burnt solder connection on the pcb, just a described. Have run 4 loads since my re-solder; a novice looking job, but all is working now. Thanks for the very good info.
Please replaced our control module and the dishwasher is back to working again. Part was about $125 and installation took no more than 15 minutes. Very simple and easy fix. It might help you determine the problem so you can order the correct part you need.
