renomorse
#1 Posted : Tuesday, December 2, 2008 7:19:01 AM(UTC)
renomorse
Fresh food setting is turned all the way down to one and it is freezing my foods. I also have the freezer side turned down to number two. Also the ice and water
dispenser does not work.In fact it makes no ice at all.
#2 Posted : Wednesday, December 3, 2008 12:10:31 PM(UTC)
A cause of a such problem could be a bad damper control and/or a bad main control board.
The main control board operates with all functions of your refrigerator and I would suspect this part first because of two separate problems: wrong temperature and not working dispenser.
- The part number for the main control board is AP4297272
#3 Posted : Wednesday, December 3, 2008 2:07:06 PM(UTC)
You also may have a clogged condenser. If ok, measure the back freezer wall temperature and post.
