when baking -- oven kicks out breaker at breaker box. stove top works well. 16 years old. Is this a major problem or a simple fix?
Originally Posted by: joepop ...when baking -- oven kicks out breaker at breaker box... How long after start does it? Gene.
breaker kicked out about 1 hour after start . After it was reset it kicked again in about 20 minutes ( not real sure about the 20 minutes ). This has happened 2 or 3 times .
I would check the connections at the breaker first (power off). They can loosen over time. I would do a visual inspection of the elements and replace the breaker (they go bad too), before starting on the oven.
