joepop
#1 Posted : Tuesday, December 2, 2008 7:08:36 AM(UTC)
joepop
when baking -- oven kicks out breaker at breaker box. stove top works well. 16 years old. Is this a major problem or a simple fix?
#2 Posted : Wednesday, December 3, 2008 11:24:19 AM(UTC)
Originally Posted by: joepop Go to Quoted Post
...when baking -- oven kicks out breaker at breaker box...
How long after start does it?
joepop
#3 Posted : Wednesday, December 3, 2008 3:05:13 PM(UTC)
joepop
breaker kicked out about 1 hour after start . After it was reset it kicked again in about 20 minutes ( not real sure about the 20 minutes ). This has happened 2 or 3 times .
gobtool
#4 Posted : Thursday, December 4, 2008 3:15:11 AM(UTC)
gobtool
I would check the connections at the breaker first (power off). They can loosen over time. I would do a visual inspection of the elements and replace the breaker (they go bad too), before starting on the oven.
joepop
#5 Posted : Thursday, December 4, 2008 3:51:33 AM(UTC)
joepop
Thanks, I'll try that.
