amarr003
#1 Posted : Tuesday, January 18, 2011 7:36:31 AM(UTC)
amarr003
New Years day I went to use my dishwasher and it stopped working. It showed no signs of life. No response from any of the controls on the control panel. I immediately checked the power from the outlet and I had 122 Volts. I probed several points on the control board and the control board was receiving the full 122 Volts. I also made sure that the door latch was functioning properly as well as the float switch. I have no other information that I can provide other than I would like to know if simply the control board stopped functioning or if the control panel died? Is there a way I can troubleshoot either component further. Or even worse...am I completely off and do I have a different problem?
magician59
#2 Posted : Tuesday, January 18, 2011 11:11:25 AM(UTC)
magician59
Check the electrical connections under the machine and make sure the ground wire is firmly connected. If it is, I would first suspect the touch pad.
amarr003
#3 Posted : Tuesday, January 18, 2011 11:16:24 AM(UTC)
amarr003
Is there a way to troubleshoot the touchpad before replacing it?
magician59
#4 Posted : Tuesday, January 18, 2011 11:36:15 AM(UTC)
magician59
They're really tricky because of the very small contact area in the ribbon connector. One thing you can do is very gently "clean" the contacts in the ribbon, using a soft pencil eraser. Then reconnect the ribbon and see if it made a difference. Also very closely inspect the control board for any indication of damage, like burnt components or charring.
Be a ware that even with the door open and the inside panel removed, there is still live voltage in it. Use extreme care.
