billy706
#1 Posted : Sunday, January 16, 2011 6:03:43 PM(UTC)
billy706
How do I remove a panel to check to see what is leaking, When I wash using hot water it leaks a quart to a gallon from under washer, I suspect a supply to pump hose but unsure what to remove or how to look inside.
sidfink43
#2 Posted : Wednesday, January 19, 2011 5:54:06 AM(UTC)
sidfink43
I cannot get your model number to come up. It should be a set of letters and numbers with no gap. If you will check it and repost we might be able to give you some guidance.
billy706
#3 Posted : Thursday, January 20, 2011 1:28:10 PM(UTC)
billy706
LA9800XTN0 Is the model, I'm sure it's a simple fix, I just don't want to mess it up trying to fix it. Thanks !
sidfink43
#4 Posted : Thursday, January 20, 2011 4:38:31 PM(UTC)
sidfink43
Ok, good.
This video will show you how to take off the cabinet. It is very easy, a little more difficult to get it back on but with patience and cussing you will be able to do it.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
