How do I remove a panel to check to see what is leaking, When I wash using hot water it leaks a quart to a gallon from under washer, I suspect a supply to pump hose but unsure what to remove or how to look inside.
I cannot get your model number to come up. It should be a set of letters and numbers with no gap. If you will check it and repost we might be able to give you some guidance.
LA9800XTN0 Is the model, I'm sure it's a simple fix, I just don't want to mess it up trying to fix it. Thanks !
