sticks on last 2 inches of closing, does not spring open. have cleaned and oiled. can you help? thanks rob
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Post the compactor model number. Should be on a tag inside the storage compartment above the drawer.
Hi rbern007 The first thing I would check is the lock on the right side of the container. See if everything is in place. The second thing I would check if the ram is in the upper position. You also can pull the t/c out of the cabinet, remove the top cover and check the ram position from the top. - Here are the break down diagrams for the Jenn Air trash compactor Model TC507QGood luck. Gene.
