rbern007
#1 Posted : Monday, October 8, 2007 10:49:35 AM(UTC)
rbern007
sticks on last 2 inches of closing, does not spring open. have cleaned and oiled.
can you help?
thanks
rob
Admin / APP Team
#2 Posted : Monday, October 8, 2007 1:22:55 PM(UTC)
Admin / APP Team
Rank: Administration
Post the compactor model number. Should be on a tag inside the storage compartment above the drawer.
rbern007
#3 Posted : Monday, October 8, 2007 6:39:28 PM(UTC)
rbern007
model TC507Q0
thanks
#4 Posted : Thursday, October 11, 2007 9:34:29 PM(UTC)
Hi rbern007
The first thing I would check is the lock on the right side of the container. See if everything is in place.
The second thing I would check if the ram is in the upper position. You also can pull the t/c out of the cabinet, remove the top cover and check the ram position from the top.
- Here are the break down diagrams for the Jenn Air trash compactor Model TC507Q
Good luck.
