wet after spin cycle, I thought the pump problem, I changed it. but the problem still same " wet " , after investigate the high spin, some time good but many times are slow ......... please help !
Check the belt. Also possible overload and/or dis-balance. Here are the break down diagrams for the Maytag washer Model PAV2200AWWGene.
Thank you, Sir.
Belt Changed already together with pump, when i test run everything running good except spin cycle was slow (at blue line )
After that I turn to another spin cycle (at light brown line), it spinning really good.
I try again to another spin cycle (at dark brown line), it spinning really good.
One more time at blue line, now it spinning really good.
I though the problem was gone, but when i washed, the clothes still wet.
Is the timer a problem ? (may be the contactor getting bad) or something else ? please help again. :confused:
Thanks.
You may have a worn thrust bearing. The thrust bearing is what releases the brake in the spin cycle. Do you sometimes hear a rubbing or grinding noise in spin? As the thrust bearing wears, it doesn't fully release the brake. This will cause a slow spin.
Thank you,
OOppp ...... I'll check it. Now it seem running normal but i'll prepare for
Thank you,
OOppp ...... I'll check it, but now it seem running normal, I'll prepare for thrust bearing.
Thanks so much, Sir.
