a3d
#1 Posted : 16 years ago
a3d
wet after spin cycle, I thought the pump problem, I changed it.
but the problem still same " wet " , after investigate the high spin, some time good but many times are slow ......... please help !
#2 Posted : 16 years ago
Check the belt. Also possible overload and/or dis-balance.
Here are the break down diagrams for the Maytag washer Model PAV2200AWW
a3d
#3 Posted : 16 years ago
a3d
Thank you, Sir.
Belt Changed already together with pump, when i test run everything running good except spin cycle was slow (at blue line )
After that I turn to another spin cycle (at light brown line), it spinning really good.
I try again to another spin cycle (at dark brown line), it spinning really good.
One more time at blue line, now it spinning really good.
I though the problem was gone, but when i washed, the clothes still wet.
Is the timer a problem ? (may be the contactor getting bad) or something else ? please help again. :confused:
Thanks.
magician59
#4 Posted : 16 years ago
magician59
You may have a worn thrust bearing. The thrust bearing is what releases the brake in the spin cycle. Do you sometimes hear a rubbing or grinding noise in spin? As the thrust bearing wears, it doesn't fully release the brake. This will cause a slow spin.
a3d
#5 Posted : 16 years ago
a3d
Thank you,
OOppp ...... I'll check it. Now it seem running normal but i'll prepare for
a3d
#6 Posted : 16 years ago
a3d
Thank you,
OOppp ...... I'll check it, but now it seem running normal, I'll prepare for thrust bearing.
Thanks so much, Sir.
