ddrhodes7
#1 Posted : Thursday, January 13, 2011 7:48:55 AM(UTC)
ddrhodes7
I replaced the igniter on my dryer model # kgys850gz0 thinking this would solve my problem of no heat. After I replaced the ingiter I noticed it would not heat up when I turn it on. My guess is a relay not letting the igniter get power. I do not want to replace every thing. So what or who do I check the other parts? I know how to use a meter I just need directions on what to check and the values. David
#2 Posted : Thursday, January 13, 2011 2:04:02 PM(UTC)
David,
The first part you may want to check for continuity is the thermal fuse (#6 on the diagram). You have to remove the rear panel to access the part.
If the thermal fuse is open, it is recommended by the manufacturer to replace the cycling thermostat (#7) as well.
Make sure the vent line is clear all the way out.
- The thermal fuse Part number: AP3132867
- The cycling thermostat Part number: AP3131939
