groythird
#1 Posted : Thursday, January 13, 2011 6:00:18 AM(UTC)
groythird
I replaced the heating element and now it glows bright red constantly regardless of the setting. Could wires be on wrong? Could thermostat nedd to be replaced?
#2 Posted : Thursday, January 13, 2011 2:28:17 PM(UTC)
Sounds like the heating element is shorted to the ground. Double check its installation, the element itself and all wires.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE DESFL1 Frg(v6) / 27 " Electric Dryer | AppliancePartsPros.com
groythird
#3 Posted : Friday, January 14, 2011 3:59:29 AM(UTC)
groythird
I need a wiring diagram to check the wiring
#4 Posted : Friday, January 14, 2011 3:17:22 PM(UTC)
There is no on line version for this model due to age of it. You can try to contact Frigidaire.
Make sure the heating coils do not touch the body. Disconnect the wires from the heating element and check for continuity between each of terminals and the ground.
