onoff
#1 Posted : Sunday, November 30, 2008 6:27:52 PM(UTC)
onoff
My Whirlpool refrigerator/freezer starts and stops all the time. When it stops I can get it to start again when I slam the freezer door a few times not the most reliable method and right now it doesn't seem to want to start.
Any suggestions?
Thanks.
#2 Posted : Monday, December 1, 2008 4:19:20 AM(UTC)
Model Search
Here is some additional help
http://www.applianceaid.com/refrigerator.html
Check out #2, this would be at the top of my list
Sounds like a bad/loose connection or a compressor relay.
If the unit is totally dead re:no lights then you have a bad connection
Instead of slamming the door wiggle the thermostat
onoff
#3 Posted : Monday, December 1, 2008 6:58:10 AM(UTC)
onoff
Originally Posted by: denman Go to Quoted Post
Model Search
Thanks denman. FYI, the lights are on. I'll let youknowif it's acompressor relay or not.
cpatterson
#4 Posted : Tuesday, December 2, 2008 2:24:55 PM(UTC)
cpatterson
this can be easy to fix. what might be wrong with your refrigerator is one of 2 things 1 it may need a new thermostat.2 it might need a new starter
onoff
#5 Posted : Tuesday, December 2, 2008 4:15:37 PM(UTC)
onoff
Turns out it was the thermostat which both of you diagnosed correctly.
Thanks again.
