NO SMELL ( or sound) OF GAS. Separate range top has gas flow./works.OK. NO SPARK. when thermostat is turned up. WHEN I TURN THERMOSTAT DIAL , ORANGE LIGHT GOES ON. OVEN LIGHT WORKS. flat type igniter. I Just turned down the thermostat , during cooking,and failed to re- gnite. This , after a grease burn off that produced alot of smoke(?) THANX..BOBbobd1950@aol.com
Most likely the problem is a weak igniter. - The part number for the igniter is AP2934763 You have to use the mounting bracket from the old igniter. Gene.
