bobd1950
#1 Posted : Saturday, November 29, 2008 10:07:07 AM(UTC)
bobd1950
NO SMELL ( or sound) OF GAS. Separate range top has gas flow./works.OK.
NO SPARK. when thermostat is turned up.
WHEN I TURN THERMOSTAT DIAL , ORANGE LIGHT GOES ON.
OVEN LIGHT WORKS.
flat type igniter.
I Just turned down the thermostat , during cooking,and failed to re- gnite. This , after a grease burn off that produced alot of smoke(?)
THANX..BOB
bobd1950@aol.com
#2 Posted : Saturday, November 29, 2008 6:52:03 PM(UTC)
Most likely the problem is a weak igniter.
- The part number for the igniter is AP2934763
You have to use the mounting bracket from the old igniter.
