jimobsux
#1 Posted : Sunday, January 9, 2011 12:30:23 PM(UTC)
jimobsux
dear sir, this dryer is only 7 yrs old. when i try to turn the switch to the start position it only hums/buzzes and does not run. its getting power, the door switch is good obviously and i believe the belt is good because the drum does not turn freely and still has resistence. if it comes down to the motor, i dont have much money. should i just buy new dryer because i dont know how long the belt life has? thank so much for any advice.
kayakcrzy
#2 Posted : Sunday, January 9, 2011 1:37:22 PM(UTC)
kayakcrzy
The part that is most likely bad is the thermal limiter. The part # is WE04X10094. I want you to unplug the dryer. Then, get a putty knife and slide it under the top on the right side, about 3 inches from the end, and you will hit a clip. that will release the top on that side. Do the same on the other side, and then lift the top up, and rest it on the back wall. Now look inside the dryer, on back top right hand corner, there will be a small round part the size of a dine. That will be the thermal limiter. Take the 2 wires off, and slide the terminal ends together of the wires you took of, and then get some tape, and tape them up so they stay together, and no metal is showing. We don't want the metal terminal ends to hit metal. Once you have that done, plug the dryer in and see if it works. If so, I want you to unplug thye dryer, and we need to take the front off. There will be a screw on the inside of the front on the top right, abd the top left side of the inside of the front. They will be about 6 inches from the top. Remove them, and the wires to do the door switch, and then take the front off, and clean the blower housing on the bottom of the front. Then put it all back together, and order the thermal limiter. We just jumped it out for testing. You should not run the dryer with the limiter jumped out. I just wanted you to narrow down the problem. Tom ApplianceEducator.com
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
GFD55ESSN0WW GE Dryer stays on Pause when I press start (Dryer Repair)
by Guest 6/8/2022 6:54:15 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No panel lights GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:00:44 PM(UTC)
GE Dryer Model DWSR483EG9WW Squeaky & Loud (Dryer Repair)
by pdl2 12/23/2021 12:10:27 PM(UTC)
Gas GE dryer (Dryer Repair)
by Guest 6/20/2021 10:17:53 AM(UTC)
GE DRYER PART INTERCHANGEABLE (Dryer Repair)
by Guest 3/27/2021 12:02:09 PM(UTC)
GE dryer keeps pausing (Dryer Repair)
by ffltstn 3/23/2021 7:15:37 AM(UTC)
Will my GE Dryer still work (Dryer Repair)
by JW Appliance 1/29/2021 11:07:33 AM(UTC)
Trying to replace a GE dryer motor (Dryer Repair)
by Gigs34 9/8/2020 9:59:46 AM(UTC)
