Freezer works Refridgerator warm, frost build up on back of freezer. Melted the ice with blow dryer. refridge working. what part causes ice build up when failed?
Your Model Number is missing a few digits at the end so could not find info specific to your unit. KRSI25?????? Defrost problems are usually caused by: Defrost heater Defrost thermostat Defrost timer in your case I believe it is controlled by the main circuit board in the fridge section. Best to check the heater and thermostat with a meter Here is some additional helpful info http://www.applianceaid.com/refrigerator.html |
THIS FORUM IS DEAD!!!!!!! |
