valrye
#1 Posted : Saturday, November 29, 2008 5:17:08 AM(UTC)
valrye
Freezer works Refridgerator warm, frost build up on back of freezer. Melted the ice with blow dryer. refridge working. what part causes ice build up when failed?
#2 Posted : Saturday, November 29, 2008 5:42:44 AM(UTC)
Your Model Number is missing a few digits at the end so could not find info specific to your unit. KRSI25??????
Defrost problems are usually caused by:
Defrost heater
Defrost thermostat
Defrost timer in your case I believe it is controlled by the main circuit board in the fridge section.
Best to check the heater and thermostat with a meter
Here is some additional helpful info
http://www.applianceaid.com/refrigerator.html
