joer3
#1 Posted : Friday, November 28, 2008 10:49:27 AM(UTC)
joer3
i replaced rubber drain impeller (maytag part #900894) with the gray center up, and the white center down. i didnt take notice when i removed the old one. is this correct? thanks
#2 Posted : Friday, November 28, 2008 4:00:53 PM(UTC)
These two parts have a graphite rings (bearings). The black on one and the white on another one. They must face each other.
joer3
#3 Posted : Saturday, November 29, 2008 4:02:22 AM(UTC)
joer3
UserPostedImageUserPostedImageImpeller
Part Number: AP397341
Manufacturer's Number: 900894 made by MAYTAG UserPostedImageOur Price: $8.29
Compare at: $15.39
You Save: $7.10
UserPostedImage Availability:
In Stock
Order now and it will ship Monday
UserPostedImage UserPostedImage Quantity
UserPostedImage
Different views available:
UserPostedImage UserPostedImage UserPostedImage
#4 Posted : Saturday, November 29, 2008 5:29:08 PM(UTC)
If you are talking about impeller only, then the white part should face down, toward the black graphite ring on the bottom seal.
joer3
#5 Posted : Saturday, November 29, 2008 9:50:27 PM(UTC)
joer3
thanks gene
Lower drain impeller replacement (Dishwasher Repair)
by tiaric 12/19/2012 7:01:25 AM(UTC)
