This is a "built in" double electric self cleaning oven. I need to remove the outer door panel to clean the glass and interior between the glass panels.
It appears that the door must be removed to get access to the torx screws on the bottom of the door. How do you remove the door from its hinges???
Davie Nine Fingers
At the hinge there is a locking clip on each side, it has a small square hole. Get a screwdriver and pull those clips back, then slowly close the door till the door catches on those locks. Then push the door like your closing it and the hinges will release from the oven.
THANKS very much. I never would have guessed it was that easy!:)
