Gregory Smith
#1 Posted : Friday, November 28, 2008 8:04:33 AM(UTC)
Gregory Smith
Cleaned upper oven and oven has completely shutdown. power to unit is good. door is still locked. I believe the overtemp Thermistor has blown. Can information be provided as to the location and any other info to aid in removal and replacement.
abadfish66
#2 Posted : Friday, November 28, 2008 8:31:21 AM(UTC)
abadfish66
Here is the diagram of your oven--->Model KEBC277KBT0
Section 4 item# 37 is your thermister. It is located at the back of the oven, and the oven will need to be removed from the wall to get to it.
