anng
#1 Posted : Wednesday, January 5, 2011 9:47:26 AM(UTC)
anng
Bought a house from original owners one year ago, house and dishwasher were new in 2005. Original owners said they may have used dishwasher possibly 5 times total in four years, as the last time they used it it leaked out of the bottom. We are just now looking into it, pulled it out and tried it, water leaks around motor shaft onto floor. We've dug around, and have purchased a new impeller with seal kit. Is this likely the cause of leak? Hoses seem OK. Any ideas? Dishwasher essentially like new, just has the leak and would like to repair rather than replace.Motor seems fine. Thanks.
magician59
#2 Posted : Wednesday, January 5, 2011 9:56:38 AM(UTC)
magician59
It's a logical place to start. If it has been a long time since the last use, the seals may have dried out; and they can crack and leak.
anng
#3 Posted : Saturday, January 8, 2011 11:58:38 AM(UTC)
anng
Thanks very much, "magician." We now have the motor pulled out and have purchased a new impeller seal kit. It's a whirlpool DU840SWP.., about five years old. We're having trouble separating the impeller from the motor assembly.
We're about ready to chuck it and either buy a whole new pump/motor assembly, or a new dishwasher.
Any suggestions would be appreciated.
magician59
#4 Posted : Saturday, January 8, 2011 12:44:16 PM(UTC)
magician59
If it's still clean, it may be worth the cost of replacing both the motor and pump. The normal life expectancy for an appliance like this is between ten and fifteen years.
Frigidaire Leaks from bottom when water dispenser lever is pressed (Refrigerator & Freezer Repair)
by jroyals 3/6/2022 10:29:39 AM(UTC)
LG WM2140C front loader leaks from bottom (Washer Repair)
by mdq636 11/6/2012 5:41:59 AM(UTC)
GE washer leaks from bottom (Washer Repair)
by esabin 10/27/2011 11:00:14 AM(UTC)
dishwasher leaks from bottom (Dishwasher Repair)
by jasonkk 9/30/2011 4:38:56 PM(UTC)
ge washer leaks from bottom center of tub (Washer Repair)
by jedtref 8/13/2010 6:10:30 AM(UTC)
Neptune Washer leaks from bottom of door (Washer Repair)
by GregThomas 8/1/2010 9:19:30 PM(UTC)
Maytag Atlantis water leak.Seems it leaks from bottom or side of plastic tub.Nee help (Washer Repair)
by wendelg 1/31/2010 10:53:14 AM(UTC)
leaks from bottom regular cycle (Washer Repair)
by elmdodge 1/1/2010 2:10:19 PM(UTC)
Frigidaire DishWasher leaks from bottom (Dishwasher Repair)
by four2699 12/13/2009 9:49:47 AM(UTC)
by pgreen1017 12/12/2009 8:36:29 AM(UTC)
Amana washer broken belt, not turning, leaks from bottom (Washer Repair)
by JonTK 9/8/2009 9:13:04 AM(UTC)
GE Profile Leaks from bottom of tub (Washer Repair)
by kbuhagiar 4/27/2009 8:10:49 PM(UTC)
