wendelg
#1 Posted : Sunday, January 31, 2010 10:53:14 AM(UTC)
wendelg
:confused:
sidfink43
#2 Posted : Tuesday, February 2, 2010 3:09:25 PM(UTC)
sidfink43
You have been a member since:: 3/29/2009(UTC)
You will need to observe the machine running with the front panel off to locate the source of the leak.
This service manual will show you how to remove the front panel.
http://repair2000.com/Li...maytagatlantiswasher.pdf
wendelg
#3 Posted : Wednesday, February 3, 2010 8:16:37 AM(UTC)
wendelg
I have. It seems the leak is from the bottom of the plastic tub.
Could it be the seal from the bearing or the seal under the stainless tub?
Based on your experience, Should I change all seals and the bearing?
What would be approx. cost?
sidfink43
#4 Posted : Wednesday, February 3, 2010 8:36:52 AM(UTC)
sidfink43
Here is the part, but and its a very big but
Part number: AP4025154
Maytag says you need a High Torque transmission
see this service bulletin
http://www.servicematters.com/m...rary/docs/TDL-0086-B.pdf
If you do not have one call APP and see if they have the older parts available that would work with your model.
You will also need special tools.
Given the complexity and cost of this job you may want to consider replacing the machine.
bradsch
#5 Posted : Sunday, January 22, 2017 3:31:36 PM(UTC)
bradsch
You may want to be certain you can successfully remove the outer tub hub from the machine before ordering parts. It's most likely seized on and will never come off. I made this mistake after spending the $96.00 for tub seal kit. Will now return the parts and put the money towards a new washer.
