simonyoung
#1 Posted : 16 years ago
simonyoung
[FONT='Times New Roman']A round igniter glows to bright orange within seconds of turning on the oven and I smell gas but oven will not light. It is a build-in oven made by Gaffers & Sattler (a division of Magic Chef) in early 1980. The model # is EA91-5CLXM5P and serial # is 09357GA. Please advice and thank you.
[FONT='Times New Roman']The orifice hood looks like in the correct position for nature gas. I open up the air shutter and I can light up a small flame inside with a match. However the burner will not light.[/FONT]
[FONT='Times New Roman']Your online parts only shows flat igniter and it says that does not replace round igniter. Where can I found a round one?[/FONT]
[/FONT]
#2 Posted : 16 years ago
The model number you posted does not come up. Possible due to age. Call APP customer service at 877-477-7278 and ask for Adam. He will take care of it.
simonyoung
#3 Posted : 16 years ago
simonyoung
Dear Gene,
Thanks for your kind reply. Would you please help me for the following question.
[FONT='Times New Roman']I just took some measurements on the igniter (parts# GR-402) and bi-metal safety valve (parts# NC-1425-5A). The electric current is 2.59 amperes into valve and voltage across safety valve is 3.1v. The safety valve voltage spec calls for 3.3/4.0 VAC. My intuition tells me that bi-metal valve is bad. However, the lower voltage reading may be caused by defected igniter with a larger resistor. Larger resistor would lower the electric current and hence give a lower voltage across the 2 terminals of the valve. [/FONT]
[FONT='Times New Roman'] [/FONT]
[FONT='Times New Roman']Well, now I am confused. Which of the valve or igniter that I should replace? Is there possible that neither is defective and I should check on other component?[/FONT]
#4 Posted : 16 years ago
Sounds like the igniter is too weak. Normally the current drawn by a round igniter should be between 2.5 to 3.0 amps. 2.59 amps is very close to the bottom line, causing the gas valve not to open properly.
- The APP part number for the GR-402 round igniter is AP3537311
simonyoung
#5 Posted : 16 years ago
simonyoung
Thank you very much, Gene. I will replace the igniter and hopefully it will work.
Simon
Kitchen Aid/whirlpool oven does not light on the first try (Oven Repair (including Ranges and Cooktops))
by Deintinis 4 years ago
KITCHENAID OVEN DOES NOT LIGHt (Oven Repair (including Ranges and Cooktops))
by PCircenis 9 years ago
GE oven does not light (Oven Repair (including Ranges and Cooktops))
by dlkreamer 12 years ago
Whirlpool oven does not light, stove works fine (Oven Repair (including Ranges and Cooktops))
by pop702 12 years ago
oven does not light stove top and broiler does (Oven Repair (including Ranges and Cooktops))
by zoo6 13 years ago
Oven does not light (Oven Repair (including Ranges and Cooktops))
by MeanGene 13 years ago
Kenmore Oven Does Not Light (Oven Repair (including Ranges and Cooktops))
by Amphicar770 14 years ago
Gas Oven Does not light up (Oven Repair (including Ranges and Cooktops))
by PLANZ 15 years ago
by Eileen1963 16 years ago
by jkerr 17 years ago
by tomkovic 17 years ago
Oven igniter clicks twice but oven does not light (Oven Repair (including Ranges and Cooktops))
by smanager 17 years ago
