simonyoung
#1 Posted : Thursday, November 27, 2008 10:55:43 PM(UTC)
simonyoung
[FONT='Times New Roman']A round igniter glows to bright orange within seconds of turning on the oven and I smell gas but oven will not light. It is a build-in oven made by Gaffers & Sattler (a division of Magic Chef) in early 1980. The model # is EA91-5CLXM5P and serial # is 09357GA. Please advice and thank you.
[FONT='Times New Roman']The orifice hood looks like in the correct position for nature gas. I open up the air shutter and I can light up a small flame inside with a match. However the burner will not light.[/FONT]
[FONT='Times New Roman']Your online parts only shows flat igniter and it says that does not replace round igniter. Where can I found a round one?[/FONT]
[/FONT]
#2 Posted : Friday, November 28, 2008 12:42:48 PM(UTC)
The model number you posted does not come up. Possible due to age. Call APP customer service at 877-477-7278 and ask for Adam. He will take care of it.
simonyoung
#3 Posted : Thursday, December 4, 2008 1:17:04 PM(UTC)
simonyoung
Dear Gene,
Thanks for your kind reply. Would you please help me for the following question.
[FONT='Times New Roman']I just took some measurements on the igniter (parts# GR-402) and bi-metal safety valve (parts# NC-1425-5A). The electric current is 2.59 amperes into valve and voltage across safety valve is 3.1v. The safety valve voltage spec calls for 3.3/4.0 VAC. My intuition tells me that bi-metal valve is bad. However, the lower voltage reading may be caused by defected igniter with a larger resistor. Larger resistor would lower the electric current and hence give a lower voltage across the 2 terminals of the valve. [/FONT]
[FONT='Times New Roman'] [/FONT]
[FONT='Times New Roman']Well, now I am confused. Which of the valve or igniter that I should replace? Is there possible that neither is defective and I should check on other component?[/FONT]
#4 Posted : Thursday, December 4, 2008 8:55:47 PM(UTC)
Sounds like the igniter is too weak. Normally the current drawn by a round igniter should be between 2.5 to 3.0 amps. 2.59 amps is very close to the bottom line, causing the gas valve not to open properly.
- The APP part number for the GR-402 round igniter is AP3537311
simonyoung
#5 Posted : Thursday, December 4, 2008 10:22:30 PM(UTC)
simonyoung
Thank you very much, Gene. I will replace the igniter and hopefully it will work.
Simon
Guest (4)
Kitchen Aid/whirlpool oven does not light on the first try (Oven Repair (including Ranges and Cooktops))
by Deintinis 11/22/2020 7:42:29 AM(UTC)
KITCHENAID OVEN DOES NOT LIGHt (Oven Repair (including Ranges and Cooktops))
by PCircenis 1/22/2016 8:17:28 AM(UTC)
GE oven does not light (Oven Repair (including Ranges and Cooktops))
by dlkreamer 3/25/2013 12:26:12 PM(UTC)
Whirlpool oven does not light, stove works fine (Oven Repair (including Ranges and Cooktops))
by pop702 1/29/2013 3:56:07 PM(UTC)
oven does not light stove top and broiler does (Oven Repair (including Ranges and Cooktops))
by zoo6 3/8/2012 8:08:24 PM(UTC)
Oven does not light (Oven Repair (including Ranges and Cooktops))
by MeanGene 2/19/2012 2:10:22 PM(UTC)
Kenmore Oven Does Not Light (Oven Repair (including Ranges and Cooktops))
by Amphicar770 5/2/2011 5:40:21 PM(UTC)
Gas Oven Does not light up (Oven Repair (including Ranges and Cooktops))
by PLANZ 3/3/2010 4:05:28 PM(UTC)
by Eileen1963 6/2/2009 12:11:36 AM(UTC)
by jkerr 2/25/2008 3:37:00 PM(UTC)
by tomkovic 1/9/2008 12:38:37 PM(UTC)
Oven igniter clicks twice but oven does not light (Oven Repair (including Ranges and Cooktops))
by smanager 1/3/2008 11:35:55 AM(UTC)
