vasquem1
#1 Posted : Tuesday, January 4, 2011 3:16:20 PM(UTC)
vasquem1
My Dryer makes noise. Can some point me in the right direction on where to look to ID where noise is coming from? Thanks
sidfink43
#2 Posted : Wednesday, January 5, 2011 5:32:04 PM(UTC)
sidfink43
If the noise is not coming from the motor/fan, then here is the likely culprit.
Part number: AP4008534
I would replace the belt, pulley, idler arm and bearings at the same time and you should be good to go.
Maytag Maxima Dryer makes noise when heated. (Dryer Repair)
by souydalay 10/7/2015 2:52:06 PM(UTC)
dryer makes noise but no start (Dryer Repair)
by joe7875 7/23/2013 4:26:05 PM(UTC)
Gas Dryer Makes Noise, Takes Forever To Dry (Dryer Repair)
by cynthia89 2/7/2013 10:26:48 AM(UTC)
Amana Electric Dryer makes noise (Dryer Repair)
by SVCtech 7/16/2009 12:59:30 PM(UTC)
grandma's gas dryer makes noise (Dryer Repair)
by tonja4 6/18/2009 1:46:48 PM(UTC)
Dryer Makes Noise (Dryer Repair)
by mjkleinman 5/7/2009 9:49:12 AM(UTC)
dryer makes noise when tumbling (Dryer Repair)
by Roeboat109 11/16/2008 6:34:04 PM(UTC)
