My Dryer makes noise. Can some point me in the right direction on where to look to ID where noise is coming from? Thanks
If the noise is not coming from the motor/fan, then here is the likely culprit. Part number: AP4008534
I would replace the belt, pulley, idler arm and bearings at the same time and you should be good to go.
